This indeed does the trick, but I don't understand:The inside walls are all of the same width!
1 hour ago, driesdokter said:This indeed does the trick, but I don't understand:The inside walls are all of the same width!
Yes, but maybe that width is right on the threshold. If you very slightly reduce the wall line width, do all the walls get printed?
burtoogle 508
There is a print thin walls setting, make sure that is enabled.
