Posted · Missing setting for auto bed levelling
Hi
I use auto bed levelling by calling G29 in my "start G code" and it works like a charm.
I have a 300 x 300 bed and I probe 6 x 6, in other word it is 36 times, that the Z axe will move over the same
part of the lead screw, for every print I do, this will over time, mean wear and tear on that part of the lead screw,
after all it is just brass on stainless steel in most cases.
My suggestion is that Cure create the G29 command so that only the area that is used for printing is probed.
To extra printer settings is needed:
Use Auto Bed Levelling
Grid Size For Bed Levelling
G29 have a lot of extra parameters so I believe it's already possible.
Hope You will consider.
Thanks for a great slicer.
Best regards
Asger
