Posted · Add moisture indicator to PVA?
I have silica gel with a moisture indicator, which turns from dark blue when dry, into pink when moist.
To the Ultimaker-developers: maybe you could try adding this moisture-sensitive pigment to the PVA? Then people can see at a glance if their PVA is still dry enough?
I don't need it, since I only have single nozzle UM2-printers. But moist PVA seems to come up again and again here on the forums.
