Cura on Raspberry pi From Distro Errors
psyberbob
Posted · Cura on Raspberry pi From Distro Errors
Hi there;
I am running Cura on a 3B+, and I cannot get it to lad.
The pacgake was installed from the repository, so it should work right out of the box.... However...
ERROR TRACEBACK:
Quote
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/cura/Settings/MachineManager.py", line 970, in setSettingForAllExtruders
for key, extruder in self._global_container_stack.extruders.items():
AttributeError: 'NoneType' object has no attribute 'extruders'
LOGS:
Quote
Thread 0x5cbf4460 (most recent call first):
File "/usr/lib/python3/dist-packages/UM/Backend/Backend.py", line 155 in _storeStderrToLogThread
File "/usr/lib/python3.7/threading.py", line 865 in run
File "/usr/lib/python3.7/threading.py", line 917 in _bootstrap_inner
File "/usr/lib/python3.7/threading.py", line 885 in _bootstrap
Thread 0x5d3f5460 (most recent call first):
File "/usr/lib/python3/dist-packages/UM/Backend/Backend.py", line 147 in _storeOutputToLogThread
Thread 0x5e437460 (most recent call first):
File "/usr/lib/cura/plugins/RemovableDriveOutputDevice/RemovableDrivePlugin.py", line 61 in _updateThread
Thread 0x5ecf0460 (most recent call first):
File "/usr/lib/cura/plugins/USBPrinting/USBPrinterOutputDeviceManager.py", line 66 in _updateThread
Thread 0x5f66d460 (most recent call first):
File "/usr/lib/python3.7/threading.py", line 296 in wait
File "/usr/lib/python3.7/threading.py", line 427 in acquire
File "/usr/lib/python3/dist-packages/UM/JobQueue.py", line 86 in _nextJob
File "/usr/lib/python3/dist-packages/UM/JobQueue.py", line 116 in run
Thread 0x5fe6e460 (most recent call first):
Thread 0x6066f460 (most recent call first):
Thread 0x60e70460 (most recent call first):
Thread 0x616b1460 (most recent call first):
File "/usr/lib/python3.7/threading.py", line 300 in wait
File "/usr/lib/python3/dist-packages/zeroconf.py", line 1794 in wait
File "/usr/lib/python3/dist-packages/zeroconf.py", line 1365 in run
Thread 0x61eb2460 (most recent call first):
File "/usr/lib/python3/dist-packages/zeroconf.py", line 1219 in run
Thread 0x626b3460 (most recent call first):
File "/usr/lib/python3/dist-packages/zeroconf.py", line 1140 in run
Thread 0x62eb4460 (most recent call first):
File "/usr/lib/python3.7/threading.py", line 552 in wait
File "/usr/lib/cura/plugins/UM3NetworkPrinting/UM3OutputDevicePlugin.py", line 274 in _handleOnServiceChangedRequests
Current thread 0x76f5cad0 (most recent call first):
File "/usr/lib/python3/dist-packages/cura/CrashHandler.py", line 364 in _logInfoWidget
File "/usr/lib/python3/dist-packages/cura/CrashHandler.py", line 214 in _createDialog
File "/usr/lib/python3/dist-packages/cura/CrashHandler.py", line 82 in __init__
File "/usr/bin/cura", line 101 in exceptHook
File "/usr/lib/python3/dist-packages/UM/Qt/Bindings/ControllerProxy.py", line 98 in _onActiveStageChanged
File "/usr/lib/python3/dist-packages/UM/Signal.py", line 315 in __performEmit
File "/usr/lib/python3/dist-packages/UM/Signal.py", line 212 in emit
File "/usr/lib/python3/dist-packages/UM/Controller.py", line 162 in setActiveStage
File "/usr/lib/python3/dist-packages/cura/CuraApplication.py", line 768 in runWithGUI
File "/usr/lib/python3/dist-packages/cura/CuraApplication.py", line 687 in run
File "/usr/bin/cura", line 141 in <module>
cura.cfg
[general]
version = 6
[backend]
[view]
[local_file]
[um3networkprinting]
[gcodereader]
[layerview]
[info]
[cura]
Plugins
{"disabled": [], "to_install": {}, "to_remove": []}
Any help would be appreciated.
        • 1 reply
