New mimetype: howto register it?
Daniel26
Posted (edited) · New mimetype: howto register it?
Hello,
I wrote a plugin which I wan't to start by a new mimetype. But how do I register that mimetype?
My __init__.py in the plugins directory:
def getMetaData():
    if "ChituCodeWriter.ChituCodeWriter" not in sys.modules:
        return {}
    return {
        "mesh_writer": {
            "output": [
                    "mime_type": "text/chitu-g-code",
                    "mode": MeshWriter.OutputMode.TextMode,
                    "extension": "chitu",
                    "description": i18n_catalog.i18nc("@item:inlistbox", "chitu addons")
Is that really enough so I can call that plugin via the printers definition with
"file_formats": "text/x-gcode;text/chitu-g-code",
Regards
Daniel
Edited by Daniel26
    Sorry, here is the complete __init__.py
    import sys
    from UM.Logger import Logger
    try:
        from . import ChituCodeWriter
    except ImportError:
        Logger.log("w", "Could not import ChituCodeWriter")
    from UM.i18n import i18nCatalog #To translate the file format description.
    from UM.Mesh.MeshWriter import MeshWriter #For the binary mode flag.
    i18n_catalog = i18nCatalog("cura")
    def getMetaData():
            return {}
        return {
            "mesh_writer": {
                "output": [
                        "description": i18n_catalog.i18nc("@item:inlistbox", "Chitu Code")
    def register(app):
            return {}
        return { "mesh_writer": ChituCodeWriter.ChituCodeWriter() }
    How can I be sure that the new mimetype is known by cura?
    I don't see any signs that my plugin is used.
    Regards
    Daniel
    Edited by Daniel26
    Posted · New mimetype: howto register it?
    File -> Export should allow you to at least try to export as a .chitu file (Save as type). That is, unless ChituCodeWriter fails to import. If ChituCodeWriter fails to import, that should be visible in the logs.
    Ok. Thats for testing.
    What I wan't: if printer is a tronxy, the g-code should be created, that g-code hat to be modified by my plugin.
    How can I do that? Is that done by "file_formats": "text/x-gcode;text/chitu-g-code" in the printers definition?
    Sorry for that stupid questions, but I can't find any info about "Mesh_writer" Plugins.
    Regards
    Daniel
    What sort of modifications are you talking about? Does the modified gcode file have to be named *.chitu? If not, it is easier/less confusing for the user to not use a meshwriter, but use something that simply post-processes the gcode when it is written.
    If you still want to go the MeshWriter route, I would suggest you take the GCodeGzWriter as an example/starting point:
    https://github.com/Ultimaker/Cura/tree/master/plugins/GCodeGzWriter
    https://github.com/Ultimaker/Cura/blob/master/plugins/GCodeGzWriter/GCodeGzWriter.py shows how to let the GCodeWriter to actually create the gcode file string, which you can then modify before you write it to the output stream.
    It adds e.g. a Screenshot to the gcode so the part is shown on the touchscreen of the printer. The timestamps also have a special format.
    I tried to submit a post process script, but they won't include it in the cura release. They advised me to write a mesh writer plugin and to submit it to the plugin database.
    Edited by Daniel26
    Ok, then have a look at the UFPWriter as an example instead.
    To Use the UFPWriter I have to "save as" and select "UFP"?
    If yes, this is not what I wan't.
    If I add a Tronxy printer the gcode simply has also "run thru" my plugin ans should be saved as gcode.
    Yes, unless you specify your printer prefers using the mimetype specified in the UFPwriter plugin, like so:
    "file_formats": "application/x-ufp;text/x-gcode"
    Note how application/x-ufp is in front of text/x-gcode
    Do you want to write multiple files at once (ie: a thumbnail and a gcode file in two separate files)? That is not something the MeshWriter supports easily. You would have to build that yourself.
    Quote
    So, If I understand correctly: The file generated from ufp is "piped thru" the Script that creates the gcode? So with the order of the fileformats I can control the order the plugins are used?
    Quote
    Nope. There are only additional M-Commands included in the gcode-file. So I only wan't one file.
    No, that is not correct. There is no automatic piping of anything. The order of mimetypes just specifies what MeshWriter plugin is preferred for that printer. Only one MeshWriter gets called by Cura, but a MeshWriter might call other meshwriters.
    I'm sorry, I don't have time to hold your hand on this at the moment.
    No Prob, thanks. I will try to figure it out. Sadly, there is no documentation about that.
    Hmmm, my Plugin seems not to be registered. I put a simple "print" to the register and the getMetaData function, but I can't find the output in any log.
    Any idea?
    Not without either the full code you use (and where you put it) or a link to your cura.log
    Here the __init__.py:
    #Copyright (c) 2018 Ultimaker B.V.
    #Cura is released under the terms of the LGPLv3 or higher.
    import sys
    try:
    except ImportError:
    def getMetaData():
        print("Loading chitu_mods metadata")
            return {}
        return {
            "mesh_writer": {
                "output": [
                        "extension": "gcode",
                        "description": i18n_catalog.i18nc("@item:inlistbox", "Chitu gcode")
    def register(app):
            return {}
        else:
            print("fregistering chitu_mods")
    Cura.log is attached.
    Thanks for your time
    cura.log
    Do you have a plugin.json? I don't think the plugin is loaded unless there is a plugin.json file with the appropriate data in it.
        "name": "Chitu code Writer",
        "author": "Spanni26",
        "version": "1.0.0",
        "description": "Adds chitu code to gcode",
        "api": "7.1",
        "i18n-catalog": "cura"
    Yes, see above.
    So, where did you put those files then?
    The print() in getMetaData() works for me. But since getMetaData() returns {} (because there is no ChituCodeWriter), register() never gets called.
    How do you run Cura? print() statements are not logged. They show up if you run Cura from source, but don't end up in cura.log. If you want entries in cura.log, use UM.Logger.Logger.log() instead.
    Ok, thanks. Will try the logger.
    The file are in a seprate folder in the plugins dir.
    Ok, tried it now with the logger, but still no message in the logs:
    import sys
    try:
    except ImportError:
    def getMetaData():
        Logger.log("w", "--- get metadata of ChituCodeWriter ---")
            return {}
        return {
            "mesh_writer": {
                "output": [
    def register(app):
        Logger.log("w", "--- register  ChituCodeWriter ---")
            return {}
        else:
    Nothing in the logs.
    I also have no such mime type in the save-as-dialog.
    Frustrating...
    Regards
    Daniel
    It is also frustrating trying to help you when you don't answer simple questions.
    I start cura simply from windows with a double click on the icons.
    What else do you need? I will try to answer the questions.
    The source of the plugin is here: https://github.com/Spanni26/Cura/tree/master/plugins/ChituWriter
    Edited by Daniel26
