Nozzle Switch Un-Retractions *after* extruder positioning
AbeFM
Posted · Nozzle Switch Un-Retractions *after* extruder positioning
I have an IDEX printer, and when one nozzle retracts, and parks, the second nozzle will unretract, then move to the location for the print - often leading to a small blob on the nozzle which ends up on the object.
While I have been able to use a prime tower to dump the extra on, I would like to print without using one - prints occasionally fail due to prime tower issues, especially on variable layer heights.
Is there a way to ensure the un-retract happens AFTER the extruder switch is complete and the nozzle is above the part, or perhaps as a stop-gap do another retract until the nozzle is at the right spot.
        • 27 replies
