Cura resets plugins parametsrs with every new object
holoped
Posted · Cura resets plugins parametsrs with every new object
Is there a way to make the plugin setup permanent ?
I use TweakAtZ to make the first layer hotter so it would stick better,
this works very well but I have to add and config the plugin for every object
I want to print.
Also, is there a plugin that moves the head up when retracting ?
Best,
HP
