Lost Calibration in X-Axis UM3
m_mueller
Posted · Lost Calibration in X-Axis UM3
Hi there,
Need some Help.
I am Printing with a UM3. After a aborted Print the x-axis moves to far. A calibration box 100x100mm Prints with 110x100mm.
Factory reset and new Firmware had no effect. Did a Calibration for the printcores and the x-Calibration field was ca.10mm larger than the Print.
Tried changing Microstepping with M92 X78.74 - no effect.
Any suggestions are welcome.
