The bad vertical alignment of the text in the printer settings dialog has recently been fixed for a future release.
The squares in the gcode text areas are an ongoing issue as discussed recently in https://github.com/Ultimaker/Cura/issues/2452
I am having the same issue but I have the latest version.
Edit: This started after installing the octoprint plugin, likely unrelated
Edited by TheRealJoe24
fatiguingsummary 0
Any solution to this? Still having this problem unfortunately.
Thank you.
