On 4/1/2020 at 2:03 AM, ahoeben said:Cura is not limited to any maximum nozzle size; the printer definition you selected probably is. If you add a new printer to Cura, and start with a Custom FFF printer, you can set any nozzle size you want in the Machine Settings.
He means that if you set up a printer, then go to Extruder, it only gives you from .2 to 1.mm nozzles as options.
There's no obvious way to set it to 1.2mm.
What YOU seem to be saying is that we can make a whole custom printer, for a single nozzle. Seems like a crappy solution.
ahoeben 1,766
