40 minutes ago, burtoogle said:Have you tried using the max comb distance with no retract setting?
Hi, yes I have it modified. However, the idea is different: release some pressure in the nozzle while doing combings, performing a tiny retraction.
Edit: I'm also seeing right now that Cura is ignoring the "max comb distance without retract", I set it at 100mm and it's still doing combings instead of retractions on long travels.
Edit2: ok it is working, it's doing retractions before long combings. But the problem that some plastic is extruded is still there.
Edited by Neukyhm
burtoogle 505
