You *could* customize your printer profile start code to prime the nozzle, but getting it to make a continuous line all the way from the corner to the start of your part might not exactly work out that easily from manually entered Start G-code, and would need to be manually recalculated for the next print job, or even if you change the position slightly of the first part, or the print order changes.
You may just need to calibrate the retraction settings for the A8. You might have luck just turning off retractions entirely, although this might result in stringing issues. OR.... You might just need to set some "retraction extra prime" amount. I'd try setting the retraction prime amount first, probably a number between 1.4 and 4.0
BenMarolt 0
Edited by BenMaroltLink to post
