I unfortunately do not have a gcode for a good print. Here's a bad one though
Thanks for the file. Looking at the gcode you can see that the model is not totally solid. There's an inner ring and the threads are not connected to it. Here's a slice through the gcode that shows what I mean...
I would have expected to only see walls on the inside and outside of the part with infill between the walls. It looks like a modelling problem to me.
- 1
Looks like you are right. Thanks for the help.
burtoogle 514
Can you please attach sample gcode for a good thread print and a bad thread print? Thanks.
