I use pla filament. Run at 230 degrees to the white-blue and gold color filament Bed 60 degrees.
Edited by Johnniej
Edited by Johnniej
Ok, could you perhaps share a picture of your hot end to see if anything is out of the ordinary? What diameter is the filament? Can you share some pictures of the prints that were successful?
1 hour ago, SandervG said:Hi @Johnniej, welcome to the community!
Can you give us some more information regarding which type of filaments you bought, besides the color?
For example, blue PLA exists, but so does blue ABS and CPE. Same goes for many other colors. And it is the type of material that defines the printing temperature over which color it is.
So perhaps you are not printing at the correct temperature. Alternatively, it could be that your nozzle is clogged, but if 1 materials is printing correctly and the other is not, then I am inclined to think you're not using the right settings for that material.
Thanks
19 minutes ago, SandervG said:Ok, could you perhaps share a picture of your hot end to see if anything is out of the ordinary? What diameter is the filament? Can you share some pictures of the prints that were successful?
I
Thanks
SandervG 1,499
Thanks
