Theyre both custom built printers
Yes, although somehow one shows up as local, and one as network enabled. Both are accessed through octoprint, and the octoprint plugin works fine for both.
But to answer your question, both were entered as custom fff printers.
Could you zip up your configuration folder and DM me a link?
I've had a look at your files.
You have configured one of your printers to use 2.85mm material, and the other to use 1.75mm material. Cura filters materials by approximate material diameter for each printer, so you don't accidentally select a 2.85mm material for a 1.75mm printer.
Edited by ahoebenAn oversight on my part. Both printers are 1.75.
Thank you for finding this!
With all the help you've given me over the past few days, I finally have a cura configuration that I can use. The only anomaly I see is that 1 printer is tagged as "Network ready" and the other is "Local", whereas both of them are connected to my network via octoprint. Despite this difference, I see no difference in the operation of either printer.
Thanks again. I will be busy over the next few days tinkering with the settings.
1
7 hours ago, jbernardis said:he only anomaly I see is that 1 printer is tagged as "Network ready" and the other is "Local", whereas both of them are connected to my network via octoprint.
A screenshot would be nice.
FWIW, the "Network enabled printers" category is mostly for networked Ultimaker printers. I am not quite sure how an OctoPrint-connected printer would promote itself to a "Network ready" printer.
ahoeben 1,582
Are they different printers? If so, what printers?
