Material changer with S5: gratuitous material extrusion at end of job
Posted
· Material changer with S5: gratuitous material extrusion at end of job
My understanding is it extrudes filament as the end to make a tip on the end of the filament so that it s able to feed in and out from the feeder without blobs getting broke off inside and making it unable to load again. It's also why other brand of filaments need to be confirmed because the process needed for other brands might not be 100% the same to make a nice tip.
Posted
Thank you Carla!
I suppose that makes sense, but in all the time I was using my S5 without the material station I had no problems with blobs broken off, etc. Furthermore, it seems like the printer spends an inordinate amount of time extruding at the end, if just for that purpose.
As a retired engineering director I feel that one of the major issues is the debris accumulating at the bottom of the printer. I've already had a case where extruded filament got caught up in the print head fan, jamming it, and another instance where the waste filament started wrapping itself aggressively around the Z-axis table screw.
I am thinking of prototyping several solutions to this; one involving a collapsing "shield" and another involving a pair of chutes that vacuum the waste filament out.
Carla_Birch 115
TheOldCodger 0
Thank you Carla!
