Ok thanks, I can try this later when I go back to my printer. It seems like the menus are similar between the S3 and S5 but I should've mentioned this is the S5.
I should add that when I first tried my print, I get a message that it could not complete active leveling. I did a self calibration by adjusting the 3 knobs and using a sheet of paper to feel for when I felt enough friction to slightly grab the paper (it still moved relatively freely). I tried my print again and it went through the active leveling where it touches the glass with no problem.
Are there any other suggestions? I don't know anything about 3D printers but I have a feeling this will not be the issue since it passes the active leveling test. I will definitely try though.
Guest maht
I don't have an S3 in front of me right now, but can you look for an option on the display along the lines of: SYSTEM > Maintenance > Diagnostics > Bed level sensor
This will test the performance of the capacitive sensor in the print head to see if it's defective.
