UM2+ still a valid choice for 3d printer!!
RudydG
Posted · UM2+ still a valid choice for 3d printer!!
I use a S5 and a normal 3, on a daily base. But these are not fast machines. The second nozzle does impact speed and quality. So i just added a new 2+ to do my single material prints, nothing can beat this machine in single material prints.
I know that i am not alone in this thinking.
    +1
    If it's single extrusion and it fits the build plate I also prefer the UM2.  My most used machine is my UM2 upgraded with a duet3D board, it just has the best workflow. I do usually use the S5 for the more  exotic materials.
    Im new to the UM family as i just got a UM2 that has the + upgrade done. what did the duet3D board do for you? I have a robo3d, a Gmax xl+, and now the UM2+. my robo3d has about everything on it modded my Gmax is stock. The only thing i want to fix on my UM2+ is the noise, I have lots of squeaks cumming form somewhere in the gantry and i get a high pitch sound coming form one of my driver/ stepper motor on movement form one part/move to new location.
    Something is wrong, my 2+ is my most quiet machine. How many hours on it?
    3 hours ago, ultiarjan said:
    +1
    I have a complete Duet with big screen lying around, what would i gain by modding my 2+?
    Biggest thing for me is ease of use, just send the file to it directly from Cura, monitor progress on your phone, do a reprint directly from the screen (if you have it) or just any device with a browser. Just total control from any device.
    The control and ease of experimentation is also great, you control the whole setup from a few txt files, no more recompiling firmware, just a reboot.  Also the machine becomes even more quiet.
    got a picture?
    I just did some serious maintenance on my 2 Ultimaker 2's (early 2014) . Cleaned all pulley's, got a new belt kit, new bowden,  cleaned all rods, z-rod, z-nut, new ptfe thingy in the printhead (and I may forget something) basically spend some time and maybe 50 to 100 euro and the machine feels like new again, for me it really made a difference, specially in the noise department....
    13 minutes ago, RudydG said:
    got a picture?
    One of my Ultimaker2's is still original (apart from Tinkergnome's firmware), the 2 machines in the picture both have a duet board. On the left the UM2 with the 7"screen, which is silly, the 5"would look much better.... on the right my DIY Ultimaker GO extended, with the 5"screen. The screen position is not very smart if you want to use a front cover on the machine...
    Posted (edited) · UM2+ still a valid choice for 3d printer!!
    Yes, the 7inch looks silly, but i have that lying around... But maybe i can connect it with some sort of extension cable, and not fix it on the printer, but use it "on the side"
    But to be honest, the only advantage is see is the wifi transfer of files. seems like a lot of work to archive that. 😭😁😳
    Edited by RudydG
    Yep, mounting it on the left side using a hinge to be able to fold it in could work well
