Support on curved overhang
TedM
Posted · Support on curved overhang
I'm finding that a different support angle is required to avoid supports depending on if the overhang is straight or curved.
As an example, I have a 45 degree overhang which I have sweep along a straight line and along an arc in FreeCAD, as seen here:
If I slice it with support overhang angle set to 46, I get this:
The straight sweep does not get a support while the arc sweep does. The cross section is the same on both. I have to raise support overhang angle to 48 to avoid the support. This seems wrong to me. Is there a setting I'm missing? Am I wrong or is this a bug?
BTW, I'm running Cura 4.6.1 on Windows 10.
Attached are the STL file and the FreeCAD project (zipped) to reproduce it.
Thanks
support test.stl support test FCStd.zip
