Guest maht
Framar is right, check your model is assigned to an enabled extruder!
okay i found out , i had deactivate extruder 1 in cura because when it export the Gcode it show as t0 but my machine as t1 and t2 , it mostly a bug from cura , extruder 1 wasnt selected but deactivate and causing cura to not slice , enabling it and switching to the right extruder 2-3 and it work thank you
Yep, it uses a zero index, so t0 = extruder 1, t1 = extruder 2, and so on.
Framar 39
I think that is because it is asssigned to a disable extruder.
