Posted · Ender 5 and BLTouch whoes
Good afternoon to you all. I wonder if anyone can help me with this predicament?
I’ve installed the BLTouch and the modified Marlin 2.0.1 firmware.
On running through the BLTouch setup the nozzle goes to the centre correctly and does 2 levelling checks then stops around 10mm off the surface
I go to the z axis and move it to 0.00. This then gives me around a 5mm gap.
I then go to the z offset to adjust to the final 0.2mm setting but on turning this the z axis doesn’t move? Even after dialling in 8mm on the display?
Can anyone help? Please
          • Heart
        • 4 replies
