Posted · Layer View Issues
Is this an update on Cura? My computer updated and now, every time I go onto layer view, you can see through your model and you can't see supports that well because it's stuck on Line Type and I can't change it. How can I change it from Line Type to something like Layer Thickness?
    Never mind. I just turned on 'Force Layer Compatibility Mode' (Or something like that) in Preferences. Though that does lead me to another issue. When using Line Type or Material Color on anything like that, Cura just leaves it colorless like this (First picture) and whenever I try to go down a few layers (i.e layer 100 to layer 88) it turns blank (Picture 2) and I have to press the play button to get it back, but it still remains colorless and every time I need to check if the infill or what layer the support stops or something like that, it turns blank like picture 2 and it's pretty annoying to have to press play every time you need to see something. Is there any way to fix this?
    • Thegladster changed the title to Layer View Issues
