Hi Enigma
I have never had to remove a print core before. In the power off should it pop out effortlessly after piching the two spring loaded levers? I don't want to force anything after my head flood.
Hi Enigma
yes, the print core is only held by the clamping of its housing.
If you take the "spare" print core shipped with your printer (if you're using the BB in slot 2 of the print head: the AA core or vice versa), you can see two recesses on top of the translucent part of the lever. Into these recesses grips a notch from the printhead, so if you pull the printcore out straight, it won't come out easily. That's why I suggested a little pressure down while pulling (other users just wiggle the printcore loose).
The following youtube-video might also be helpful:
https://www.youtube.com/watch?v=EjHPfKQKQQ4
Regards
Enigma_M4 77
first to get clear: if you say "remove the nozzles", you mean removing the printcore from the print head (as the nozzle, which is part of the printcore, cannot be removed without a high risk of breaking the heatbreak, which will definitely ruin the printcore)?
Removing the printcore(s) is normally done via menu, but can also be done with the printer powered off (I'm talking about UM3, but as the printcores are identical and the printhead is nearly identical, this should also work un the S5):
The filament must be unloaded from the printcore(s). Then flip down the front fan bracket, compress the print core levers and pull out the print core to the front (apply a little bit of pressure on the upper side of the lever while pulling).
Print core 2 has to be in the lower position for removing.
Reinstalling is just vice versa: compress print core lever, slide print core in print head slot til it clicks, close fan bracket (and reload material).
I hope I could help.
Regards
