It's not using any QT environment variables for the fonts. Instead, it's using what is defined in the theme files. You can find them in the app image inside resources/themes/
The default one is cura-light and you chan change the fonts used in the theme.json file.
Posted
(edited)
· AppImage (Linux) bad fonts when scaled
Well I'm aware of the theme files. However, to change them you have to unpack the AppImage and either repack it or keep it unpacked, which would be OK. However, it looks like it is a scaling issue. I tried setting a theme JSON on 4.6 locally but didn't try it in the AppImage tree which now that I think about it makes sense. I will try that but I doubt it will fix my issue. But we'll see -- I'd like to be wrong.
Oh yeah -- I forgot. The AppImage mounted is RO and remounting it RW doesn't help. So I would then say the only way to do that would be to copy the AppImage tree somewhere else to do that. I'll still try it.
Edited by wd5gnr
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
nallath 1,067
wd5gnr 0
Edited by wd5gnrLink to post
