Thank you for your reply. You are correct about the "Slicing Tolerance" setting, I had set it to exclusive based on a suggestion I found elsewhere as something to try for better dimensional accuracy.
Honestly, I didn't understand from reading the description of that feature that it would impact the number of layers. I still don't get it but I will set it back to its default setting.
Thanks again for the help.
Cuq 162
Yes you are right in this case the number of layer must be 200. And this is what we have in a normal configuration.
But in your case you have certainly modify one parameter in the experimental section. This parameter is call Slicing Tolerance , by default it's set to Middle but in your case should be change to Exclusive and in this case the result is 198 layers
Edited by CuqLink to post
