Posted (edited) · Missing support when "Support Z Distance" is zero
Yes strange ?  Using an other configuration ( different machine)  I have also an issue by using 0 as value but not so critical ?
But one solution to solved this problem is simply use not 0 but 0.001 Should not make a big difference and it's solved your problem.
Or just use a regular value for the support overhang angle : 45°   why do you use this very low value of 30° ?   in your case even a 70° should be fine to get a correct result and in this case you don't need using  some stop support blocks
Edited by Cuq
