Extrusion flow rate.
toothpaste
Posted · Extrusion flow rate.
New to Cura.  -   Trying to calibrate my extruder in Cura 4.6.1. When looking for flow rate settings, or others I have gone to :-  Settings - Configure setting visibility - Checked "all" - then return. But I do not get an expanded set, of settings? Could anyone explain what I doing wrong please.
Further if I may. Can I send an "M503" command in Cura to display and check eprom settings at all. Since I would need to read to read the steps/mm to adjust the flow rate.
Your kind attention appreciated.
        • 31 replies
        • 24 replies
