GregValiant 1,488
Fixed.
It was me all along. I would leave a bit of Bowden tube sticking out of the inner heat sink tube so that when I installed the nozzle it would assure a seal. Turns out a little is a lot and the bottom of the tube was distorting and getting too narrow. So I threw out my not-so-great idea and all is good. I think I'll go sit in a corner now with the pointy dunce hat on.
I do have the coolest hot end in town though.
GregValiant 1,488
Well, there have been no suggestions so I ordered a replacement hot end fan. My current theory (theory #41a) is that some strings have wound around the shaft of the fan rotor and it isn't putting out what it should. I arrived at this theory because everything besides the fan has already been replaced. I ordered a Delta 4015 and will put a 1/8" spacer behind the metal cover to move it outboard 3.2mm. That should allow the 12cfm fan to fit inside. Theory #41b states that Creality put all the cheapest stuff they could get away with in the machine along with cutting the physical requirements as close as they could. I figure you can't over-cool the hot end. If 80% more air doesn't cure the problem I'm gonna design a dry ice system.
