Hellol Enigma_M4
Thanks for the reply, I've found it.
On 7/1/2020 at 8:19 PM, Enigma_M4 said:there must be a "move filament" function, but don't ask me where it is placed at the S3.
On UM3, it is placed in the material/print core menu, nearby the load and unload command.
That is the place.
If anybody else missed it:
In the Material/Print Core menu select the material
In the Material menu select the context menu by the dots in the upper right corner
In the context menu use the "Move" button
to open the Move Material menu
1
Enigma_M4 77
The quick and dirty solution to transport the partly retracted material back to the print core is also: open feeder-lever, push filament manually until it stops, close feeder-lever.
Regards
