Attached is a project and gcode file
I also included the Gcode file for my test tower
bf_v3_base_WH120_JGY370_0degrees.3mf _bf_v3_base_WH120_JGY370_0degrees.gcode Test Tower brim STL CURA.gcode
Labern 774
Hi there.
It looks like with this part there are problems with some of the thin wall settings.
You mentioned every print over 90mm. Are there other models without thin wall at the top that you have tried printing that have the same results?
If it's only this model, would you be able to share a project file so we can look at your setting and check the model under layer view?
