Posted · OpenGL crash on multplying model/importing 2nd copy via .3mf
seems no matter what i do, i cant get 2 models on 1 build plate. If i import 1 from fusion and click multiply, i can continue to use cura, but the progress bar for the multiplying progression stays at 0%. If i import a model from an stl or 3mf cura crashes with the following errors and reinstalling has not been able to fix my issue, this only just started occurring today.
Thread 0x00001ea0 (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.6\plugins\USBPrinting\USBPrinterOutputDeviceManager.py", line 86 in _updateThread
File "threading.py", line 862 in run
File "threading.py", line 914 in _bootstrap_inner
File "threading.py", line 882 in _bootstrap
Thread 0x00002a30 (most recent call first):
File "threading.py", line 297 in wait
File "zeroconf\__init__.py", line 2117 in wait
File "zeroconf\__init__.py", line 1434 in run
Thread 0x0000233c (most recent call first):
File "threading.py", line 549 in wait
File "C:\Program Files\Ultimaker Cura 4.6\plugins\UM3NetworkPrinting\src\Network\ZeroConfClient.py", line 74 in _handleOnServiceChangedRequests
Thread 0x00000af4 (most recent call first):
File "zeroconf\__init__.py", line 1262 in run
Thread 0x00005638 (most recent call first):
File "zeroconf\__init__.py", line 1183 in run
Thread 0x00005360 (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.6\plugins\RemovableDriveOutputDevice\RemovableDrivePlugin.py", line 61 in _updateThread
Thread 0x000011e8 (most recent call first):
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 161 in _storeStderrToLogThread
Thread 0x00004efc (most recent call first):
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 149 in _storeOutputToLogThread
Thread 0x00001230 (most recent call first):
File "threading.py", line 293 in wait
File "threading.py", line 424 in acquire
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 98 in _nextJob
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 123 in run
Thread 0x000039d0 (most recent call first):
Thread 0x000045a4 (most recent call first):
Thread 0x00005080 (most recent call first):
Thread 0x000047b8 (most recent call first):
Thread 0x00003264 (most recent call first):
Thread 0x00000620 (most recent call first):
Thread 0x00004fd8 (most recent call first):
Thread 0x000029c0 (most recent call first):
Thread 0x000028d0 (most recent call first):
Thread 0x00003498 (most recent call first):
Thread 0x000035c4 (most recent call first):
Current thread 0x0000399c (most recent call first):
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 379 in _logInfoWidget
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 180 in _createDialog
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 86 in __init__
File "C:\cura-build-output\build\inst\bin\cura_app.py", line 166 in exceptHook
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\UM\Qt\QtApplication.py", line 378 in exec_
File "C:\cura-build-output\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py", line 813 in run
File "C:\cura-build-output\build\inst\bin\cura_app.py", line 234 in <module>
File "Console.py", line 24 in <module>
File "<frozen importlib._bootstrap>", line 634 in _load_backward_compatible
File "<frozen importlib._bootstrap>", line 664 in _load_unlocked
File "<frozen importlib._bootstrap>", line 957 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 968 in _find_and_load
File "__startup__.py", line 12 in <module>
    Posted (edited) · OpenGL crash on multplying model/importing 2nd copy via .3mf
    Moving from cura 4.6.2 back to 4.6 has resolved my issue. It seems this is directly related to 4.6.2, i had tried multiple different drivers for my 2080 ti as well as using the integrated GPU with the same results.
    Further investigation shows i messed up the Disallowed Areas section when editing the ender 3 profile and left an extra bracket that caused a crash when a multiplied object was placed on the disallowed area.
    Would be nice for this feature to be disabled in the profile instead of a config edit, i use photo clips instead of binder clips so i only have 2mm of the clip holding onto the glass plate on my ender 3s.
    Edited by rectify
    Sounds like you got things working again, which is great. For the record, it would be nice if you mention you have manually edited your printer profile, so when we try to reproduce your problem we don't have to wonder why it works just fine for us but not for you. Also thanks for pasting the logs, but it would have been more helpful to also have the Error traceback.
