Thickness Below 3mm no infill, solid fill
dlum0612
Posted (edited) · Thickness Below 3mm no infill, solid fill
Hi All,
I am printing a character from a video game that is quite big. He is holding a weapon and the handle of the weapon gets pretty thin. Is there a setting within cura to make it so that the entire print has infill except for areas that are very thin like the handle (specify less than 3 mm) where it'll make the handle part solid and print the rest of the part with infill? Attached is a picture of the cross section of the handle. Right now it will print with 3 walls and some infill. I'd rather it just be solid here, but have the rest of the print have infill.
Thanks
Edited by dlum0612
