Pull back the mesh on the print head, and check that all the wires are plugged in. Note that there should be 1 connector coming from the electronics under the printer, towards the print head, that isn't connected to anything.
Under the printer, the cover over the electronics can be removed by undoing a couple of nuts I think. Once it's off, it's pretty easy to check if all the wires are properly seated in their connectors.
Also, while you're at it, make sure that the fan on the back of the print head comes on as soon as you turn on the power, and stays on all the time. That has been a fairly common problem, usually down to loose connectors at the print head end, also.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
illuminarti 18
