tinkergnome 929
I think you can't plug a thermistor into the normal temperature input of UM2 mainboard, because it's designed for PT100 elements. That's why the upgrade kit from your link came with a PT100 sensor.
How have you connected the thermistor from the E3D hotend? And does the firmware reports reasonable temperature values?
Plushberry 0
I did try the PID values that are listed in the firmware changes as well, but no luck.
