Have you made the wall thickness an exact multiple of the nozzle diameter? Then export to STL using a fine-setting, so the segments are not too long and don't cut corners too much. But even then there will be places where total thickness is slightly more and where it is slightly less than in your design, due to the straigth lines of the segments. Not sure how the slicer will handle this. And then print rather slow (and cool to prevent overheating the filament in the nozzle), so there is no underextrusion. Before printing the whole model, try cutting out the most critical part and try to optimise that, so you don't waste too much material and time.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
geert_2 462
