UlrichC-DE 109
Forgot to mention. Normally the lever places the ball bearing with the filament against the tooth roller.
As far as I remember. Do not unscrew it very often. I have controlled myself in this respect.
Good luck
Good luck
15 minutes ago, UlrichC-DE said:Forgot to mention. Normally the lever places the ball bearing with the filament against the tooth roller.
Good luck
31 minutes ago, UlrichC-DE said:Sounds familiar.
About 33 years ago (maybe there were more) I also disassembled a lot of things.
Completely by accident and couldn't get it back together. 😅
Turn the lever. It is wrongly attached in your video.
Also the cover has to be on it. The feeder doesn't work without it.
Can you take a video or email me at oysterv.j@gmail.com?
Unfortunately I cannot record a video right now.
The printer is at another location.
On the center of the manual-lever is an eccentric (red arrow) that pushes the bearing-lever.
You can take out the bearing-lever under the bearing and turn the manual-lever.
I found a picture here in the forum.
That looks better.
Yeah that part broke off on my lever
UlrichC-DE 109
Sounds familiar.
