Why is is doing this ????!?!
Oystervjh
Posted · Why is is doing this ????!?!
Sounds familiar.
About 33 years ago (maybe there were more) I also disassembled a lot of things.
Completely by accident and couldn't get it back together. 😅
Turn the lever. It is wrongly attached in your video.
Also the cover has to be on it. The feeder doesn't work without it.
    15 minutes ago, UlrichC-DE said:
    Forgot to mention. Normally the lever places the ball bearing with the filament against the tooth roller.
    As far as I remember. Do not unscrew it very often. I have controlled myself in this respect.
    Good luck
    31 minutes ago, UlrichC-DE said:
    Sounds familiar.
    Can you take a video or email me at oysterv.j@gmail.com?
    Posted (edited) · Why is is doing this ????!?!
    Unfortunately I cannot record a video right now.
    The printer is at another location.
    On the center of the manual-lever is an eccentric (red arrow) that pushes the bearing-lever.
    You can take out the bearing-lever under the bearing and turn the manual-lever.
    I found a picture here in the forum.
    That looks better.
    Edited by UlrichC-DE
    Something wrong. Too many levers
    Yeah that part broke off on my lever
    You have to rotate this part (red arrows from your video)
