Yes I saw that there is no m220 command but still the print is going really fast. That is why I noticed the high feedrate value.
GregValiant 1,489
Try putting an M220 S100 at the beginning of the Gcode file. If that works then put one in the Start-Up gcode in Cura so it will get added to every file. You'll still want to chase down what is really going on with the high feed rates.
GregValiant 1,489
Feed Rate % is set by M220 and there isn't one in either file. The problem has to be in the printer/firmware.
In the second file the skirt is printing at a sedate 20mm/sec so at 800% it would be 160mm/sec which is really flying. Is that what it's doing? If it's moving relatively slowly then the display is wrong but the feed rate setting is correct at 100%.
