Maybe try an easier shape/model just to get a feeling what is important.
I will give designing it a try in 360 or tinkercad but I will have to learn them first 😉
For the beginning use tinkercad, it is much easier to learn.
Otherwise Fusion is so powerful, so you should definitely learn it.
I ended up trying it in both TinkerCad and Fusion360 and gave up too steep a learning curve and too different to FreeCAD. So I re-drew it in FreeCAD doing it differently and it sliced fine and is now printing. 😀
Thanks for all the help and suggestions.
1
Glad it worked!
When you know FreeCad it makes no sense to learn another software when you are happy with it.
1
Smithy 1,111
The STL is a solid block, so why should it slice as hollow?
Have you designed it as hollow? Can you post a screenshot of the model in Freecad which shows that it is hollow?
