Sadly that did not seem to fix the issue, even when I set the minimum layer time to 0.
GregValiant 1,330
You've probably been looking at all the settings but is the prime tower enabled? Or a wipe or nozzle clean or a plug-in?
Edited by GregValiant- 1
Thank you so very much! It was "Wipe nozzle between layers" that was causing the issue. Thanks so much for the help. 🙂
GregValiant 1,330
Until someone shows up who knows what they're talking about - look under "Cooling" at Minimum Layer Time and Lift Head. You have a small cross-section there and Cura may be letting each layer cool sufficiently before continuing to the next layer.
