Printing temperature initial layer and initial layer flow
Posted
(edited)
· Printing temperature initial layer and initial layer flow
The flow rate multiplier (M221) will not be in the Gcode. The E-numbers are calculated at the higher flow rate so there is no need to tell the printer/planner. It's the same as speed changes. The "F" numbers are calculated at the rate you set in Cura and there is no need for M220 in the Gcode.
When I checked this problem out (4.7beta), the 2nd M104 line was in the Gcode but it was well before the start of the second layer. In the model I was using it was 300 lines of code before the layer change. That does seem odd as I thought it would be right at the end of "layer 0". A hot end doesn't need that long to cool down.
You have "M104 S{material_print_temperature_layer_0}"in the start Gcode with the "S" and the curly brackets correct? Cura should put the temp number in place of the variable name, then later in Layer:0 (but maybe not at the end) there should be that second M104 with your actual print temp in it.
Slice a model with the Initial Layer Flow at 100%, then check the last E number of Layer:0. Slice the same model again but with the Initial Layer Flow set to 200% and the last E number of Layer:0 should be 2X what it was at 100%.
Edited by GregValiant
GregValiant 1,330
You have "M104 S{material_print_temperature_layer_0}" in the start Gcode with the "S" and the curly brackets correct? Cura should put the temp number in place of the variable name, then later in Layer:0 (but maybe not at the end) there should be that second M104 with your actual print temp in it.
Edited by GregValiantLink to post
