If you have the latest version of Cura there is a post-processing plugin "Change at Z". You can put more than one instance in your file. I think I heard some noise that it was glitchy, but it works OK for me.
The other alternative is to do it by hand in Notepad and insert M220 S??? at the layers or Z height where you want to change speeds. The bottom layer in Cura is Layer 1. The bottom layer in a Cura generated Gcode file is Layer 0.
Speed and Flow changes made using M220 (or M221 for flow) in the Gcode change the printer calculations and they do not go back to 100% at the end of a print. If I make speed or flow changes in the gcode I always put a line right at the end M220 S100 or M221 S100 to make sure if I start another print right away it starts at 100%. Those settings do return to 100% if you power off the printer and turn it back on.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
GregValiant 150
