It's a custom coreXY machine, Hypercube style
You mean "Extruder Start/End G-code" ? I wonder how to do this efficiently enough. If I add some code to move extruders away from the model while heating between tool change, it will make printing time quite a bit longer.
Ideally I'd like inactive extruder to reach printing T right in time, while the other head is printing.
It seems like Cura is actually trying something of that sort but very poorly. While printing I see some strange target T for inactive head, not defined anywhere in settings. For example standby T 200, printing T 240, octoprint shows target 215.
But the result is always the same, extruder will stop about 5mm over the model for anywhere between 5 to 30 second, oozing and melting everything.
tinkergnome 926
If the firmware of the printer does not handle this, there are extruder (start/end) scripts in Cura that are intended to be used for these "extra stuff" that shall happen on every tool change.
Is it a custom printer or do you use one of the pre-defined multi-extruder configurations in Cura?
Extruder scripts can be created and edited in Cura machine settings (AFAIK).
