You can also have a look at the smart slice plugin sourcecode. They also do something with it: https://github.com/tetonsim/is-cura-ui/tree/master/SmartSlicePlugin
nallath 1,125
Yeah, that should be possible. It's not entirely there already, but you can have a look at the lay flat in the rotation tool. That allows you to pick faces already.
Cuq 208
Ok I will investigate this code ...
Cuq 208
I'm still avaing some problem to implement this code . I can get the facette center point and the normal with
But I'm still fighting with the possibility to have in the same time the subroutine _onSelectedFaceChanged and def event(self, event) . An idea or a suggestion to move forward on this point ?
