Cura Plugin - getPickedPosition
Cuq
Posted · Cura Plugin - getPickedPosition
Ok I will investigate this code ...
    def _onSelectedFaceChanged(self):
        if not self._select_face_mode:
            return
        self._handle.setEnabled(not Selection.getFaceSelectMode())
        selected_face = Selection.getSelectedFace()
        if not Selection.getSelectedFace() or not (Selection.hasSelection() and Selection.getFaceSelectMode()):
            return
        original_node, face_id = selected_face
        meshdata = original_node.getMeshDataTransformed()
        if not meshdata or face_id < 0:
            return
        if face_id > (meshdata.getVertexCount() / 3 if not meshdata.hasIndices() else meshdata.getFaceCount()):
            return
        face_mid, face_normal = meshdata.getFacePlane(face_id)
        object_mid = original_node.getBoundingBox().center
        rotation_point_vector = Vector(object_mid.x, object_mid.y, face_mid[2])
        face_normal_vector = Vector(face_normal[0], face_normal[1], face_normal[2])
        rotation_quaternion = Quaternion.rotationTo(face_normal_vector.normalized(), Vector(0.0, -1.0, 0.0))
        operation = GroupedOperation()
        current_node = None  # type: Optional[SceneNode]
        for node in Selection.getAllSelectedObjects():
            current_node = node
            parent_node = current_node.getParent()
            while parent_node and parent_node.callDecoration("isGroup"):
                current_node = parent_node
        if current_node is None:
            return
        rotate_operation = RotateOperation(current_node, rotation_quaternion, rotation_point_vector)
        operation.addOperation(rotate_operation)
        operation.push()
I'm still avaing some problem to implement this code .  I can get the facette center point and the normal with
But I'm still fighting with the possibility to have in the same time the subroutine _onSelectedFaceChanged and def event(self, event)  . An idea or a suggestion to move forward on this point ?
