Cura settings to make the second extruder print the dissolvable support
FlyGhost
Posted · Cura settings to make the second extruder print the dissolvable support
I’m using AstroPrint which is backed by Cura 15.04 to slice. I wanted to use my 2nd extruder to be printing the support only, where I’d supply the dissolving support.
I cannot seem to find the right settings is this even available?
    I think it is much better to use a newer version of Cura, slice it there and use Astroprint just for sending the job to your printer. Cura 15.04 is more than 5 years old.
    Hmm I’ll check out newer versions again, but historically I was using Cura and I simply could not obtain a good print like I used to with the newer versions. I have had decent results with AstroPrint. So I suspect it’s their printer profile over mine?
    You can hardly compare the version 15.04 and newer versions, too much has changed internaly.
    I have used the old Cura version only for some tests with basic prints. In newer versions it is not a problem, but I am not sure if you can configure it in that way with 15.04.
