Infill mesh has walls and won’t line up
connerr13
Posted · Infill mesh has walls and won’t line up
Hey there! So I am attempting to print a large object quickly, and to do so I’m cranking up the speed. But, on the front of it there is a higher amount of detail that I want to decrease the speed for to make sure it doesn’t mess up. So, I tried using an infill mesh only box to just change the speed of the prints to what I want, but, when I do so, it will make walls inside the print. So, to counter this, I changed the wall count to 0, which stopped adding extra walls but now the infill inside doesn’t line up at all. Do you know how to fix this where I can just change the speed and not the structure? Thanks!
    Posted (edited) · Infill mesh has walls and won’t line up
    Grid infill would be easier but triangles will do.  The first thing is to square them up to the world.  In Cura, under Infill make the Infill Line Directions [60,120].
    Then move the support mesh to an exact multiple of the Infill Line Distance in the X direction, and and exact multiple of (sqrt of 3 * Infill Line Distance) in the Y direction.
    That should get you close.
    Here is my take on what you currently have:
    And here are the same two pieces with the infill squared up, the infill line distance is 6, and the block placed at X = 0 and Y = (2 x 6 x SQRT 3) = 20.785.
    Edited by GregValiant
        • 10 replies
