Cura fails to load blender modeled box
ankingster
Posted · Cura fails to load blender modeled box
I had to print using Creatity Slicer on my Ender 3 printer because I'm unable to process the .stl file created in blender. It is a simple bow 44x44mm size but this is what it looks like loaded in cura:
I also attached an stl file. Can anyone help please?
gps_box.stl
    You have a problem with your STL File, Cura scales it to 100000% to have it in the correct size.
    What you see on the build plate is the shadow of your object. Set the Z value in the move function on the left to 0, then it should be fine.
    You have to select the model first.
    To do this without searching for the object in the "sky" 🙂 you can select it also via the object list in the bottom left corner.
    thx alot,
