Cura not rendering correctly box with cut out region on bottom layer
Posted
· Cura not rendering correctly box with cut out region on bottom layer
Your model is "non-manifold", causing Cura to loose track of what is inside and outisde. Specifically, the way you made the 4 little screw-holes on the bottom is causing problems. There seem to be no cylindrical walls connecting the top and the bottom of those cutouts.
ahoeben 1,981
