Floating temperature values cause overheating of hotend
Posted
· Floating temperature values cause overheating of hotend
This is very unlikely a firmware issue.
It is a common problem to occur on Ultimakers that are several months to a few years old. The quick fix is to switch to the other temp cable. There are 2 cables - one for each nozzle (in case you get the dual nozzle upgrade). For now - just try the other cable (you have to switch both at the print head and also underneath the printer).
UM doesn't properly crimp the wires in the cable at the connector and instead solders them. This is not good because the solder makes the cable stiffer and bending (during movement during printing) can cause these tiny strands to break - one at a time.
Switching to the other cable should help for a few more months. Also make sure you do as good a strain relief as possible. When the second cable breaks you can replace them both.
gr5 2,225
